PDU B is located on the right side of the rear of the rack. See below.
Press the ON (|) side of the toggle switches on PDU B.
Powering on PDU B will power on only half of the power supplies in the rack. The remaining power supplies will be powered on in Step 4.
The LEDs for the components should be in the following states when all of the PDU B circuit breakers have been turned on:
Power OK green LED – Blinking
Service Action Required amber LED – Off
PS1 and PS3 Power LEDs – Green
PS0 and PS2 Power LEDs – Amber
If the LEDs are not in these states, press the Power buttons at the fronts of the SPARC T4-4 servers.
Power OK green LED (front panel) – Blinking while the operating system is booting up.
The Power OK LED changes to Steady On after the operating system has booted up (this could take up to 10 minutes)
Service Action Required amber LED (front panel) – Off
Left power supply (rear panel) – Green
Right power supply (rear panel) – Off
If the LEDs are not in these states, press the Power buttons at the fronts of the Sun ZFS Storage 7320 storage controllers.
The LEDs should be:
Left power supply (rear panel) – Amber
Right power supply (rear panel) – Green
Left power supply LED (PS0 LED) – Red
Right power supply LED (PS1 LED) – Green
PS1 LED – Red
PS2 LED – Green
PDU A is located on the left side of the rack.
Press the ON (|) side of the toggle switches on PDU A.
The LEDs for the components should be in the following states when all of the PDU A circuit breakers have been turned on.
PS0 and PS2 Power LEDs – Green
Power OK green LED – On
Left power supply – Green
Right power supply – Green
Power OK LED – Off while Oracle ILOM is booting (about 3 minutes), then blinking
Left power supply LED (PS0 LED) – Green
PS1 LED – Green
PS2 LED – Green
