SPARC SuperCluster T4-4 Owner's Guide
Exit Print View
Updated: February 2016
Configuring ASR on the SPARC T4-4 Servers: Oracle Solaris 11
Note -  Do not attempt to copy and paste commands that span across multiple lines from this section. Manually type commands that span across multiple lines to ensure the commands are typed properly.
Oracle Solaris 11 includes the ability to send ASR fault events and telemetry to Oracle using xml over HTTP to the ASR Manager.
To enable this capability use the asr enable_http_receiver command on the ASR Manager. Select a port for the HTTP receiver that is appropriate for your network environment and does not conflict with other network services.
Perform the following tasks:
