Follow this procedure to register the SPARC T4-4 server with Oracle Solaris 11 or Database Domains to the ASR Manager.
# svcs asr-notify
If you see the following message:
svcs: Pattern ???asr-notify' doesn't match any instances
then confirm that the asr-notify service is installed:
# pkg list asr-notify
pkg list: no packages matching ???asr-modify' installed
then install the asr-notify service:
# pkg install system/fault-management/asr-notify
Enter the svcs asr-notify command again to confirm that the asr-notify service is working.
# svcs asr-notify STATE STIME FMRI online 16:06:05 svc:/system/fm/asr-notify:default
then the asr-notify service is installed and is working properly
# asradm register -e http://asr-manager-host:port-number/asr
For example:
# asradm register -e http://asrmanager1.mycompany.com:8777/asr
You should see screens asking for your Oracle Support account name and password. After entering your Oracle Support account name and password, you should see a notification, saying that your registration is complete:
Enter Oracle SSO User Name: Enter password: Registration complete.
# asradm list
The screen output should be similar to the following:
PROPERTY VALUE Status Successfully Registered with ASR manager System Id system-identification-number Asset Id asset-identification-number User username Endpoint URL http://asr-manager-host:port-number/asr
Upon successful results of the above commands, the registration of the ASR Manager is complete.
For more information on the process, see ASR MOS 5.3+ Activation Process (Doc ID 1329200.1).
