You create a Grid Link Data Source data source to each of the Oracle database instances during the process of setting up the multi-data source, both for these data sources and the global leasing multi-data source. When you create a data source:
Make sure that this is a non-xa data source
Target these data sources to the Dept1_Cluster1 cluster.
Make sure that the datasources connection pool initial capacity is set to 0. To do this, in the Oracle WebLogic Server Administration Console, select Services, JDBC, and then Datasources. In the Datasources screen, click the Datasource Name, then click the Connection Pool tab, and enter 0 in the Initial capacity field.
Ensure that an ONS daemon is running on your database servers at all times. You can start the ONS daemon on a database server by running the onsctl command:
start
To create a Grid Link Data source, complete the following steps:
The Create a New JDBC GridLink Data Source page is displayed.
Enter a logical name for the datasource in the Name field. For example, gridlink.
Enter a name for JNDI. For example, jdbc/gridlink.
Click Next.
Service Name: Enter the name of the Oracle RAC service in the Service Name field. For example, enter myService in Service Name.
Host Name - Enter the DNS name or IP address of the server that hosts the database. For an Oracle GridLink service-instance connection, this must be the same for each data source in a given multi data source.
Port - Enter the port on which the database server listens for connections requests.
Database User Name: Enter the database user name. For example, myDataBase.
Password: Enter the password. For example, myPassword1.
Confirm Password and click Next.
The console automatically generates the complete JDBC URL. For example:
jdbc:oracle:thin:@(DESCRIPTION=(ADDRESS_LIST=(ADDRESS=(PROTOCOL=TCP)(HOST=left)(PORT=1234))(ADDRESS=(PROTOCOL=TCP)(HOST=right)(PORT=1234))(ADDRESS=(PROTOCOL=TCP)(HOST=center)(PORT=1234)))(CONNECT_DATA=(SERVICE_NAME=myService)))
Oracle WebLogic attempts to create a connection from the Administration Server to the database. Results from the connection test are displayed at the top of the page. If the test is unsuccessful, you should correct any configuration errors and retry the test.
Click Next.
Select Fan Enabled to subscribe to and process Oracle FAN events.
In ONS host and port, enter a comma-separate list of ONS daemon listen addresses and ports for receiving ONS-based FAN events. You can use Single Client Access Name (SCAN) addresses to access FAN notifications.
Click Next.
Click Next.
