Before You Begin
When registering ASR Manager, you will be asked to type your MOS single sign on information and any proxy servers, if needed.
# asr register
1) transport.oracle.com
Your screen output should look like this:
Proxy server name: ? <proxy server name> Proxy port number: ? <proxy port number> Proxy authentication; if authentication is not required, enter -. Proxy user: <proxy user name> Proxy password: <proxy password> If this is an NTLM type proxy, enter the information below. Otherwise, enter - NTLM Domain: [?] <NTLM domain name> Enter the host the NTLM authentication request is originating from. Usually this is the hostname of the SASM server. NTLM Host: [?] <NTLM host name> NTLM support is not bundled with SASM but may be added now. 1) Download jCIFS from http://jcifs.samba.org/ 2) Extract contents and locate the jcifs-*.jar file 3) Enter full path to this file below jCIFS jar file: [?] <full path of jCIFS jar file> Note: These properties are stored in the /var/opt/SUNWsasm/configuration/config.ini file. You can update these properties if needed and then restart SASM.
Your MOS e-mail address receives output from notification of ASR problems and Service Request (SR) generation.
