For the Application Domain, log in through the 1 GbE host management network using the IP address or host name assigned to that domain. For example:
ssh -l root ssc0101-mgmt
For the Database Domain, log in through the 1 GbE host management network using the IP address or host name assigned to the SPARC T4-4 server. For example:
ssh -l root ssc01db01
For the Application Domain, Oracle Configuration Manager should be installed in the following directory:
/opt/ocm
For the Database Domain, Oracle Configuration Manager should be installed in the following directory:
/usr/lib/ocm
If the Oracle Configuration Manager is not installed in either of those directories, locate and change directories to the location where you installed Oracle Configuration Manager.
The directory where the Oracle Configuration Manager is installed will be referred to as ocm-install-dir for the remainder of these procedures.
/ocm-install-dir/ccr/bin
If you see the emCCR file in this directory, then Oracle Configuration Manager has already been installed and configured on your SPARC T4-4 server. Do not proceed with these instructions in this case.
If you do not see the emCCR file in this directory, then Oracle Configuration Manager has not been installed on your SPARC T4-4 server. Proceed to the next step.
/ocm-install-dir/ccr/bin/configCCR
E-mail address/User Name
Password (optional)
This installs Oracle Configuration Manager on your SPARC T4-4 server.
/ocm-install-dir/ccr/admin/scripts/installCCRSQL.sh collectconfig -s $SID -r SYS
XML files should be generated in /ocm-install-dir/ccr/hosts/SPARC-T4-4-server/state/review.
If the XML files were generated in this directory, proceed to the next step.
If the XML files were not generated in this directory, contact Oracle for support with this issue.
ORACLE_HOME/ccr/bin/emCCR collect
Drag the Targets button to the left and on to your dashboard.
