SPARC SuperCluster T4-4 Owner's Guide
Exit Print View
Updated: February 2016
Enable the HTTP Receiver on the ASR Manager
Follow this procedure on the ASR Manager to enable the HTTP receiver for Oracle Solaris 11 ASR Assets.
  1. Log in to the ASR Manager system as root.
  2. Verify the existing settings:
    # asr show_http_receiver
  3. Enable the HTTP receiver:
    # asr enable_http_receiver -p port-number
    where port-number is the port that you are designating for HTTP traffic.
    Note -  If you need to disable the HTTP receiver, run asr disable_http_receiver.
  4. Verify the updated configuration:
  5. Verify the HTTP receiver is up and running.
    In a browser, go to: http://ASR-Manager-name:port-number/asr
    A message will display indicating that the HTTP receiver is up and running.
