The following cautions and warnings apply to SPARC SuperCluster T4-4 systems.
![]() | Caution - Do not touch the parts of this product that use high-voltage power. Touching them might result in serious injury. |
![]() | Caution - Keep the front and rear cabinet doors closed. Failure to do so might cause system failure or result in damage to hardware components. |
![]() | Caution - Keep the top, front, and back of the cabinets clear to allow proper airflow and prevent overheating of components. |
Use only the supplied hardware.
