| Skip Navigation Links | |
| Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Gateway
Assemble the Ethernet Splitter Data Cables
Install the Gateway in the Rack
Understanding Routing Through the Gateway
Identify All Switches in the Fabric
Identify All HCAs in the Fabric
Display the InfiniBand Fabric Topology (Simple)
Display the InfiniBand Fabric Topology (Detailed)
Display the Link Status of a Node
Display Low-Level Detailed Information About a Node
Display Low-Level Detailed Information About a Port
Display the InfiniBand Fabric Partition Configuration
Display the InfiniBand Fabric Configuration
Perform Comprehensive Diagnostics for the Entire Fabric
Determine Changes to the InfiniBand Fabric Topology
Find 1x, SDR, or DDR Links in the Fabric
Determine Which Links Are Experiencing Significant Errors
Configuring the Fabric Director Node List
Fabric Director and Fabric Elements
Add or Remove an Element From the Fabric Configuration
Modify an Element of the Fabric Configuration
Exchange Master Fabric Director Status
Partitioning the InfiniBand Fabric
Remove User Partitions for Firmware Downgrade
Determine Partitions and P_Keys
Add or Remove a Port From a Partition
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Remove the Gateway From the Rack
Often you need to know the route between two nodes. The ibtracert command can provide that information by displaying the GUIDs, ports, and LIDs of the nodes along the route.
# ibtracert slid dlid
where:
slid is the LID of the source node.
dlid is the LID of the destination node.
For example:
# ibtracert 15 14
From switch {0x00212856cd22c0a0} portnum 0 lid 15-15 "SUN IB QDR GW switch mnm34-97"
[1] -> ca port {0x00212856cd22c042}[2] lid 14-14 "SUN IB QDR GW switch mnm34-97 Bridge 1"
To ca {0x00212856cd22c040} portnum 2 lid 14-14 "SUN IB QDR GW switch mnm34-97 Bridge 1"
Note - The output for your InfiniBand fabric will differ from that in the example.
For this example:
The route starts at the switch with GUID 0x00212856cd22c0a0 and is using port 0. The switch is LID 15 and in the description, the switch host’s name is mnm34-97.
The route enters at port 1 of the CA with GUID 0x00212856cd22c042 and exits at port 2. The CA is LID 14 and is within bridge chip 1.
Gateway Reference, ibtracert command
