For storage drive locations, see Storage Drive Locations and Numbering.
The exact commands required depend on the configuration of your drives. Unmount file systems or issue RAID commands as needed.
![]() | Caution - The latch is not an ejector. Do not open the latch too far to the right. Doing so can damage the latch. |
If you are replacing the drive, continue to Install an HDD or SSD Storage Drive.
If you are not replacing the drive, install a filler panel in the empty drive slot to maintain proper airflow and perform administrative tasks to configure the server to operate without the drive.
For information on how to install a storage drive filler panel, see Removing and Installing Server Filler Panels.
