Go to main content
Oracle® Server X5-2 Service Manual
Exit Print View
Updated: January 2021
Removing and Installing Server Filler Panels
Each server might be shipped with module-replacement filler panels for storage drives and PCIe cards. These filler panels are installed at the factory and must remain in the server until you replace them with a purchased option.
Before you can install an optional server component into the server, you must remove the filler panel from the location into which you intend to install the component. When you remove a storage drive or a PCIe card from the server, you must install either a replacement component or a filler panel.
See the following procedure for instructions for removing and installing the server filler panels:
Related Information
