Caution -
The disk backplane should be installed only by authorized Oracle Services
personnel.
To place the backplane into the disk cage, do the
following:
Lift the metal spring retainer [frame 1, callout 1] and position
the backplane so that it fits into the two metal brackets that are
located on the chassis side walls [1, 2].
Lower the disk backplane into the disk cage so that it engages the
three metal hooks in the disk cage [1, 3]
Continue to lower the disk backplane into the disk cage until it
is positioned in all six troughs that are located at the bottom of
the disk cage [1, 4] .
Turn the disk backplane captive screw clockwise until the disk
backplane is secure [1, 5].
Reconnect the disk backplane power cable to the disk backplane [2].
If the server has a DVD drive, perform the following steps:
