Oracle ILOM
SP firmware
Monitors environmental condition and component functionality
sensors, generates alerts, performs fault isolation, and
provides remote access.
Can function on either standby power mode or full power mode
and is not OS dependent.
Designed for remote and local access.
Preboot Menu
SP firmware
Enables you to restore some Oracle ILOM default settings when
Oracle ILOM is not accessible.
Can function on standby power and when operating system is not
running.
Local, but remote serial access is possible if the SP serial
port is connected to a network-accessible terminal
server.
Hardware-based LED indicators
Hardware and SP firmware
Indicates status of overall system and particular components.
Available when system power is available.
Local, but sensor and indicators are accessible from Oracle
ILOM web interface or command-line interface (CLI).
Power-On Self-Test (POST)
Host firmware
Tests core components of system: CPUs, memory, and motherboard
I/O bridge integrated circuits.
Runs on startup. Available when the operating system is not
running.
Local, but can be accessed through Oracle ILOM Remote System
Console Plus.
U-Boot
SP firmware
Initializes and test aspects of the service processor (SP)
prior to booting the Oracle ILOM SP and operating system. Tests
SP memory, SP, network devices and I/O devices.
running.
server.
UEFI Diagnostics
SP firmware
The UEFI diagnostics can test and detect problems on all
processor, memory, disk drives, and network ports. It is used on
new Oracle systems, such as the Oracle Server X5.2.
You can use either the Oracle ILOM web interface or the
command-line interface (CLI) to run UEFI diagnostics.
Remote access through Oracle ILOM Remote System Console
Plus.
Oracle Solaris commands
Operating system software
Displays various kinds of system information.
Requires operating system.
Local, and over network.
Oracle Linux commands
Oracle VTS
Diagnostic tool standalone software
Exercises and stresses the system, running tests in parallel.
Requires Oracle Solaris operating system. Install Oracle VTS
software separately.
View and control over network.
