Go to main content
Oracle® Server X5-2 Service Manual
Exit Print View
Updated: January 2021
Open the Server Fan Door
Servicing the server fan modules and other components located in the front of the server, such as the front indication module, the DVD drive, and disk backplanes, requires that the fan door be opened. It is also easier to remove the server top cover if you open the fan door first.
  • To open the server fan door, slide the fan door latches to the front of the server and swing the door up to the open position.
    image:Figure showing how to open the server fan door.
Related Information
