Go to main content
Oracle® Server X5-2 Service Manual
Exit Print View
Updated: January 2021
Exit BIOS Setup Utility
  1. Use the left and right arrow keys to navigate to the top-level Save & Exit Menu.
  2. Use the up and down arrow keys to select the desired action.
  3. Press Enter to select the option.
    A confirmation dialog box appears.
    image:This figure shows the settings on the BIOS Save and Exit                                 screen.
  4. In the confirmation dialog box, select Yes to proceed and exit the BIOS Setup Utility, or select No to stop the exit process.
    Note -  After modifying any BIOS settings and selecting Save Changes and Exit from the Save & Exit Menu, the subsequent reboot might take longer than a typical reboot where no settings were modified. The additional delay is required to ensure that changes to the BIOS settings are synchronized with Oracle ILOM.
Related Information
