Go to main content
Oracle® Server X5-2 Service Manual
Exit Print View
Updated: January 2021
Server Back Panel View
The following figure shows the Oracle Server X5-2 back panel and the location of power supplies, status indicators (LEDs), connectors, and PCIe slots.
image:Figure showing the back panel of the Oracle Server X5-2.
Number
Description
1
Power Supply (PS) 0
2
Power Supply (PS) 0 status indicators: Service Required LED: amber, AC OK LED: green
3
Power Supply (PS) 1
4
Power Supply (PS) 1 status indicators: Service Required LED: amber, AC OK LED: green
5
System status indicators: Locator LED: white, Service Required LED: amber, Power/OK LED: green
6
PCIe card slot 1 (This slot is for a standard PCIe card or the optional Oracle PCIe NVMe switch card. This slot is nonfunctional in single-processor systems.)
7
PCIe card slot 2
8
PCIe card slots 3 and 4 (Slot 4 is for the internal host bus adapter [HBA] card. Slot 4 is internal and is not visible from the rear of the server.)
9
Oracle Integrated Lights Out Manager (ILOM) service processor (SP) network management 10/100/1000BASE-T port (NET MGT)
10
Serial management (SER MGT)/RJ-45 serial port
11
Network (NET) 100/1000/10000 port: NET 3 (Nonfunctional in single-processor systems.)
12
Network (NET) 100/1000/10000 port: NET 2 (Nonfunctional in single-processor systems.)
13
Network (NET) 100/1000/10000 port: NET 1
14
Network (NET) 100/1000/10000 port: NET 0
15
USB 2.0 connectors (2)
16
DB-15 video connector
Note -  All of the PCIe slots comply with the PCI Express 3.0 specification and can accommodate 25 watt PCIe3 cards.
Related Information
