The server supports several different operating systems. A subset of the supported OSes are available preinstalled, depending on what was selected when the server was ordered. You can use the preinstalled OS, or install a fresh version of any of the supported OSes.
The OS installation process varies based on the OS and whether you want to use a preinstalled version or install a fresh version.
