Skip Navigation Links
Exit Print View
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Support and Accessibility
Understanding the Switch
Switch Overview
Physical Specifications
Environmental Requirements
Acoustic Noise Emissions
Electrical Specifications
Network Management Connector and Pins
Data QSFP Connector and Pins
Understanding Cabling
Routing Service Cables
Understanding Data Cabling
Preparing to Install the Switch
Installation Preparation
Installation Responsibilities
Installation Sequence
Route the Data Cables
Installing the Switch
Install the Switch in the Rack
Powering On the Switch
Connecting Data cables
Troubleshooting the Switch
Switch Hardware Problems
InfiniBand Fabric Problems
Identifying LEDs
Understanding Routing Through the Switch
Switch GUIDs Overview
Configuration Overview
Hardware Command Overview
InfiniBand Command Overview
ILOM Command Overview
Administering the Chassis
Monitoring the Chassis
Controlling the Chassis
Monitoring the I4 Switch Chip
Monitoring the Subnet Manager
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Remote Management
Understanding Oracle ILOM on the Switch
Oracle ILOM Overview
Supported Features
Installing the Oracle ILOM Firmware
Firmware Delivery
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
CLI Overview
Access the Oracle ILOM Shell From the CLI (NET MGT Port)
Access the Oracle ILOM Shell From the CLI (USB Management Port)
/SYS/Switch_Diag and /SYS/Fabric_Mgmt Linux Shells
Switch From the Oracle ILOM Shell to the Linux Shell
Switch From the Linux Shell to the Oracle ILOM Shell
Performing Daily Tasks (CLI)
Display the Date (CLI)
Display Switch Status LEDs States (CLI)
Display the Aggregate Sensors State (CLI)
Aggregate Sensor States
Display Power Supply Status (CLI)
Display Board-Level Voltages (CLI)
Board Level Voltages
Display Internal Temperatures (CLI)
Internal Temperature Sensors
Display Fan Status (CLI)
Display the Oracle ILOM Sessions (CLI)
Display the Oracle ILOM Event Log (CLI)
Checking the Status of Services (CLI)
Display the HTTP Service Status (CLI)
Display the HTTPS Service Status (CLI)
Display the SSL Certificates (CLI)
Display the SNMP Service Status (CLI)
Display the SNMP User Accounts (CLI)
Display the SNMP Service Communities (CLI)
Display the IPMI Service Status (CLI)
Display the DNS Client Status (CLI)
Display the SMTP Client Status (CLI)
Display the NTP Servers (CLI)
Verifying Other Aspects With Oracle ILOM (CLI)
Get Help on an Oracle ILOM Command (CLI)
Get Help on an Oracle ILOM Target Property (CLI)
Display the Alert Properties (CLI)
Display the Oracle ILOM User Accounts (CLI)
Display the Remote Log Hosts (CLI)
Display the Network Management Configuration (CLI)
Display the CLI Session Timeout (CLI)
Display Switch FRU ID (CLI)
Display Power Supply FRU ID (CLI)
Display the Firmware Version (CLI)
Display System Identification Properties (CLI)
Performing General Tasks on Oracle ILOM Targets (CLI)
Restart the Management Controller (CLI)
Set the Date and Time (CLI)
Enable the Locator LED (CLI)
Disable the Locator LED (CLI)
Clear the Oracle ILOM Event Log (CLI)
Set the Remote Log Hosts (CLI)
Configure the DNS Client (CLI)
Configure the SMTP Client (CLI)
Back Up the Configuration (CLI)
Switch Configuration Information Backed Up
Restore the Configuration (CLI)
Create a Snapshot of the Switch State (CLI)
Snapshot Dataset Information (CLI)
Set the Network Management Parameters (CLI)
Set the System Identification Properties (CLI)
Performing Oracle ILOM User Tasks (CLI)
Add an Oracle ILOM User Account (CLI)
Change an Oracle ILOM User’s Password and or Role (CLI)
Delete an Oracle ILOM User Account (CLI)
Managing HTTP Services (CLI)
Enable the HTTP Service (CLI)
Disable the HTTP Service (CLI)
Managing HTTPS Services (CLI)
Enable the HTTPS Service (CLI)
Install a Custom SSL Certificate (CLI)
Remove the Custom SSL Certificate (CLI)
Disable the HTTPS Service (CLI)
Managing SNMP Services (CLI)
Enable the SNMP Service (CLI)
Configure the SNMP Service (CLI)
Add SNMP Service User Accounts (CLI)
Modify SNMP Service User Accounts (CLI)
Delete SNMP Service User Accounts (CLI)
Add SNMP Service Communities (CLI)
Modify SNMP Service Communities (CLI)
Delete SNMP Service Communities (CLI)
Download SNMP Service MIBs (CLI)
Disable the SNMP Service (CLI)
Managing IPMI Services (CLI)
Enable the IPMI Service (CLI)
Disable the IPMI Service (CLI)
Managing Other Aspects With Oracle ILOM (CLI)
Enable Alerts to Send SNMP Traps (CLI)
Enable Alerts to Send PETs (CLI)
Enable Alerts to Send Email Alerts (CLI)
Disable Alerts (CLI)
Set the Oracle ILOM CLI Session Timeout (CLI)
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Firmware Overview
Verify Firmware Integrity (CLI)
Acquire the Switch Firmware Package (CLI)
Upgrade the Switch Firmware (CLI)
Web Interface Overview
Upgrade the Switch Firmware (Web)
Using the Fabric Monitor
Access the Fabric Monitor
Fabric Monitor Features
Control Panel Function
SNMP Overview
Understanding SNMP Commands
Administering Hardware (IPMI)
ipmitool Overview
Display Switch Status LED States (IPMI)
Enable the Locator LED (IPMI)
cd Command
create Command
delete Command
dump Command
exit Command (ILOM)
help Command (ILOM)
load Command
reset Command
set Command
show Command
version Command (ILOM)
Replaceable Components
Suggested Tools for Service
Servicing Power Supplies
Inspecting a Power Supply
Power Off a Power Supply
Remove a Power Supply
Install a Power Supply
Power On a Power Supply
Servicing Fans
Inspecting a Fan
Remove a Fan
Install a Fan
Servicing Data Cables
Inspecting the Data Cables
Remove a Data Cable
Install a Data Cable
Servicing the Battery
Remove the Switch From the Rack
Replace the Battery
checkboot Command
checkpower Command
checktopomax Command
checkvoltages Command
connector Command
dcsport Command
disablecablelog Command
disablelinklog Command
disablesm Command
disableswitchport Command
enablecablelog Command
enablelinklog Command
enablesm Command
enableswitchport Command
env_test Command
exit Command (Hardware)
fdconfig Command
fwverify Command
generatetopology Command
getfanspeed Command
getmaster Command
getportstatus Command
help Command (Hardware)
listlinkup Command
matchtopology Command
setcontrolledhandover Command
setmsmlocationmonitor Command
setsmmkey Command
setsmpriority Command
setsubnetprefix Command
showfruinfo Command
showpsufru Command
showsmlog Command
showtemps Command
showtopology Command
showunhealthy Command
smconfigtest Command
smnodes Command
smpartition Command
version Command (Hardware)
ibdiagnet Command
ibhosts Command
ibnetdiscover Command
ibnetstatus Command
ibnodes Command
ibportstate Command
ibroute Command
ibrouters Command
ibstat Command
ibswitches Command
ibtracert Command
perfquery Command
saquery Command
smpquery Command
Understanding SNMP MIB OIDs
OID Tables Overview
Understanding the ENTITY-MIB MIB OIDs
  1. Access the Oracle ILOM CLI.
    See Accessing Oracle ILOM From the CLI.
  2. Change the Oracle ILOM user’s configuration.
    -> set /SP/users/username password=password role=role
    • username is the user account name.
    • password is the new password.
    • role is the new role for the user.
    For the role, you can use the characters of the aucros string to enable the respective abilities:
    • a – Administrator
    • u – User management
    • c – Console
    • r – Reset and host control
    • o – Read only (operator)
    • s – Service
    Note - You can change the user password and role independently.
    For example, to change the password for the ilom-operator user:
    -> set /SP/users/ilom-operator password=knockknock
    Changing password for user /SP/users/ilom-operator...
    Enter new password again: **********
    New password was successfully set for user /SP/users/ilom-operator
    The ilom-operator user’s password is changed.
    Caution - With this procedure, it is also possible for the ilom-admin user to reset the root user password, should it be lost or forgotten. The ilom-admin user must use the USB management port to reset the root user password. See Access the Oracle ILOM Shell From the CLI (USB Management Port).
Related Information
