Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Switch
Install the Switch in the Rack
Understanding Routing Through the Switch
Display the Switch Chip Port to QSFP Connector Mapping
Locate a Switch Chip or Connector From the GUID
Display Switch Chip Boot Status
Display Switch Chip Port Status
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Understanding Oracle ILOM on the Switch
Installing the Oracle ILOM Firmware
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Remove the Switch From the Rack
On occasion, you might need to turn off a port. For example, a cable might become damaged and cause symbol errors that affect the switch chip’s performance. Use the disableswitchport command to disable a switch chip port and its respective cable connection.
# disableswitchport [--reason=reason] Switch port
where:
reason is the reason for disabling the port, Blacklist or Partition.
port is the number of the port (1–36).
Alternatively, type.
# disableswitchport [--reason=reason] connector
where connector is the number of the QSFP connector (0A–15B).
For example:
# disableswitchport Switch 14 Disable connector 9A Switch port 14 MKEY 8 0000000000000000 Adminstate:......................Disabled LinkWidthEnabled:................1X or 4X LinkWidthSupported:..............1X or 4X LinkWidthActive:.................4X LinkSpeedSupported:..............2.5 Gbps or 5.0 Gbps or 10.0 Gbps LinkState:.......................Down PhysLinkState:...................Disabled LinkSpeedActive:.................2.5 Gbps LinkSpeedEnabled:................2.5 Gbps or 5.0 Gbps or 10.0 Gbps #
Switch Reference, disableswitchport command
