Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Switch
Install the Switch in the Rack
Understanding Routing Through the Switch
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Understanding Oracle ILOM on the Switch
Installing the Oracle ILOM Firmware
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Remove the Switch From the Rack
SUN-DCS-IB-MIB MIB OID Command Syntax
Subnet Manager Agent Data Port OIDs
Understanding Performance Manager Agent OIDs
PMA Extended Port Counters Table OIDs
SUN-FABRIC-MIB MIB OID Command Syntax
Fabric Management Element OIDs
Fabric Management External Element OIDs
SUN-ILOM-CONTROL-MIB MIB OID Command Syntax
SUN-PLATFORM-MIB MIB OID Command Syntax
Understanding MIB Physical OIDs
Physical Class Extension Table OIDs
Sun Platform Sensor Table OIDs
Sun Platform Numeric Sensor Table OIDs
Understanding the ENTITY-MIB MIB OIDs
This table lists fabric element object identifiers supported by the SUN-FABRIC-MIB MIB.
