Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Floor and Underfloor Delivery of Data Cables
Overhead Delivery of Data Cables
Preparing to Install the Switch
Install the Switch in the Rack
Understanding Routing Through the Switch
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Understanding Oracle ILOM on the Switch
Installing the Oracle ILOM Firmware
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Remove the Switch From the Rack
Proper data cable installation requires the following:
Plan the cable routes and cable length needs.
Identify problematic cable route bends, minimizing the length of continuous vertical runs to no more than 2 meters (7 feet), and specify hardware to support cable routing.
Carry the entire cable to the points of connection and unroll the cable from the first connection point to the second
Keep the coil closed and pause to enable the cable to relax as it is unrolled and moved through turns.
Ensure that cable route turns are larger than 85 mm (3.4 inches) radius for optical cables and 127 mm (5 inches) radius for copper cables.
Find alternative routes for turns that are tighter.
Secure the cable to hard points and bundle it with soft, hook-and-loop fasteners.
See Data Cable Bundling.
Mediate the slack between securing points to maintain minimal cable tension and proper support.
See Floor and Underfloor Delivery of Data Cables and Overhead Delivery of Data Cables.
Label the ends of cables to identify their routes.
Rest the cable connectors on a stable surface when they are not connected.
