Go to main content
Sun Rack II User's Guide
Exit Print View
Updated: July 2018
Access Route Guidelines
If your existing loading dock meets height or ramp requirements for a standard freight carrier truck, you can use a pallet jack to unload the rack. If not, you must provide a standard forklift or other means to unload the rack, or request the rack be shipped in a truck with a lift gate.
Leave the rack in its shipping packaging until it reaches its final destination. The entire access route to the installation site should be free of raised patterns that can cause vibration, and the route must meet the requirements listed in the table below.
Description
Metric With Shipping Pallet
U.S. With Shipping Pallet
Metric Without Shipping Pallet
U.S. Without Shipping Pallet
Minimum door height
2184 mm
86 in.
2000 mm
78.74 in.
Minimum door width
1220 mm
48 in.
600 mm
23.62 in.
Minimum elevator depth
1575 mm
62 in.
1200 mm (SRII 1242)
1058.2 mm (SRII 1042)
47.24 in. (SRII 1242)
41.66 in. (SRII 1042)
Maximum incline
6˚
6˚
Minimum elevator, pallet jack, and floor loading capacity (maximum weight per rack)
1134 Kg / 2500 lb maximum weight of rack with full capacity. Verify weight capacities of elevators and shipping equipment before using them to transport rack.
Related Information
