Go to main content
Sun Rack II User's Guide
Exit Print View
Updated: July 2018
Equipment Installation Task Overview
Follow these general steps when installing equipment into the rack.
Step
Description
Links
1.
Follow all safety guidelines for the rack and the equipment.
2.
Extend the antitilt legs.
3.
Attach an antistatic wrist strap.
4.
(Optional) Adjust the RETMA rails, if needed for your equipment.
5.
Prepare factory-installed PDUs by removing shipping screws and routing cords.
Or, install PDUs into the rack, if not already installed at the factory.
Refer to the Sun Rack II Power Distribution Units User's Guide, or your third-party PDU documentation, for instructions.
6.
Install and cable the component into the rack, using cage nuts and cable management hooks when needed.
Refer to the equipment documentation for the installation instructions, plus:
7.
Prepare to service equipment in the rack.
8.
(Optional) To improve air flow through the rack, install filler panels over any open slots.
Refer to the equipment or system documentation for the specific instructions on installing and servicing the equipment into the rack. Most equipment include a Rack Alignment Template, which provides specific rackmounting instructions. For additional instructions, refer to the product installation guide or rackmounting guide.
Select the appropriate rack for the equipment you plan to install. For large equipment, or equipment that requires a large amount of space for cabling, select the deeper Sun Rack II 1242.
Ensure that your installation adequately protects equipment from excessive vibration and shock. Do not attach external devices or machinery to the rack that create excessive vibration. The vibration can damage sensitive equipment installed inside the rack.
Note - Equipment weighing 36.2 Kg (80 lb) or more must be installed within the bottom 10 U (445 mm/17.5 in.) of the rack.
Note - Ensure that installed equipment or cables do not impede the air flow through the rack.
Note - Never exceed the maximum allowable weight of installed equipment in the rack.
Related Information
