Single-Piece
Top Panel
The top cable window has three plastic panels that can be
moved left or right to provide openings for routing cables out of
the rack. The dimensions of these openings are the same for both
the Sun Rack II 1042 and Sun Rack II 1242.
1. |
Distance from the side of the rack to
the edge of the top cable window. |
234.976 mm |
9.251 in. |
2. |
Width of the two openings when the panels
are centered in the top cable window. |
50.8 mm |
2 in. |
3. |
Width of the top cable window. |
436.626 mm |
17.19 in. |
4. |
Distance from the rear of the rack to
109.982 mm |
4.33 in. |
5. |
Depth of the top cable window. |
130.048 mm |
5.12 in. |
6. |
Width of the window opening when the
panels are moved all the way to the left and right. |
260 mm |
10.24 in. |
7. |
panels are moved all the way to the left or right. |
180 mm |
7.1 in. |
