Go to main content
Sun Rack II User's Guide
Exit Print View
Updated: July 2018
Servicing Filler Panels
Follow these instructions to remove and replace the filler panels.
Note - These instructions are for the original Sun Rack II filler panels. If you are replacing other filler panels, refer to the instructions that came with the filler panels.
Related Information
