Go to main content
Sun Rack II User's Guide
Exit Print View
Updated: July 2018
Detach a Grounding Strap
For each rack panel and door, a grounding strap connects the panel or door to the rack frame. Before removing a door or a cabinet panel, disconnect its grounding strap.
  • Press down on the tab of the grounding strap's quick-release connector and pull the strap away from the frame.
    image:Figure showing how to detach a grounding strap as well as the                                 locations of the rack grounding straps.
