Go to main content
Sun Rack II User's Guide
Exit Print View
Updated: July 2018
Two-Piece Top Panel With Air Brushes
The two-piece top cable window with the air brushes at the opening is made up of a smaller panel that fits under the lip of the larger panel. The removal of the smaller panel provides a larger opening for routing cables out of the rack. The dimensions of these openings are the same for both the Sun Rack II 1042 and Sun Rack II 1242.
image:Figure showing the dimensions of the wide top cable window.
No.
Description
Metric
U.S.
1.
Distance between the PDU faces in the rack.
504.5 mm
19.86 in.
2.
Width of the top cable window.
436.626 mm
9.251 in.
3.
Distance from the rear of the rack to the edge of the top cable window.
436.626 mm
17.19 in.
4.
Depth of the top cable window.
130.048 mm
5.12 in.
