See Power Off the Rack.
The grounding strap can be found near the top front of the rack. Disconnect the strap by pressing down on the tab of the strap's quick-release connector and pulling the strap away from the connector.
The first figure shows how to remove the two-piece top panel.
The second figure shows how to remove the single-piece top panel.
