Go to main content
Sun Rack II User's Guide
Exit Print View
Updated: July 2018
Remove the Doors
  1. If necessary, unlock the front and rear doors.
    You can find the door keys in the shipping kit.
  2. Open the doors and detach the grounding straps connected to the doors by pressing down on the tabs of the grounding strap's quick-release connectors and pulling the straps away from the frame.
    Depending on the type of installed equipment in the rack, each door might have one or two grounding straps.
    image:Figure showing how to detach the grounding straps from an open                                 door.
  3. Lift both doors up and off of their hinges.
    image:Figure showing how to lift the doors of their                                     hinges.
