The filler panel option kit contains the filler panels as well as the Duosert M6 cage nuts, washers, and M6 screws required to install them in the rack.
After inserting a cage nut into a mounting hole, turn it 45 degrees to secure it into the hole.
![]() | Caution - Use these Duosert cage nuts for filler panels only. Do not use these cage nuts when installing any other equipment into the rack. |
