For proper operation and safety, all powered rackmounted equipment must be properly grounded. All PDUs, branch wiring, and receptacles must be listed as grounding-type devices. Connect each component and PDU into reliably grounded outlets.
Caution - To reduce the risk of electric shock or damage to installed equipment, never disable the grounding plug on any power cord. |
For additional grounding, attach an earth ground cable to the rack. See Attaching a Grounding Cable for instructions.
