Go to main content
Sun Rack II User's Guide
Exit Print View
Updated: July 2018
Install the Top Panel
  1. Carefully replace the top panel on the rack.
    For the two-piece top panel, place the larger section on top of the rack before inserting the edge of the smaller section under the lip of the larger section.
    image:Figure showing how to replace the two-piece top panel.
  2. Place the top panel support brace on the rear of the top panel.
    Line up the support brace screw holes with the holes in the rack frame.
  3. Using a No. 2 Phillips screwdriver, tighten five No. 2 screws to secure the support brace and the top panel to the rack frame.
  4. Open the doors and connect the grounding strap to the top panel.
    For the two-piece top panel, connect grounding straps to each panel.
  5. If necessary, power on the rack.
    See Power Off the Rack.
