You might prefer to remove the doors from the rack before adjusting the RETMA rails. For instructions, see Servicing Doors.
For the original racks, there are four sets of screws securing the rail to the frame and the support braces:
4 screws at the top the rail
3 screws securing the rail to the horizontal brace
3 screws securing the rail to the triangular brace
4 screws at the bottom of the rail
![]() | Caution - By separating the rails from the support braces in the older racks, you decrease the overall stability and strength of the rack. You can still use the horizontal brace if you move the front rails the same distance into the rack as you moved the rear rails (35 mm). |
Secure the rail using four screws at both the top and bottom of the rail. Save the remaining six M6 self-tapping screws for future use.
Secure the telescopic braces using five screws at both the middle and bottom rails.
