The top of the rack should support the weight of the side panel and ensure that the panel's fasteners line up with the grooves in the rack frame.
Turn the two fasteners next to the panel lock counterclockwise. You can find the side panel removal tool in the shipping kit. There are 10 fasteners per side panel.
You can find the locks on the bottom center of the side panels.
See Power the Rack On.
