![]() | Caution - Insert a filler panel into an empty modular system slot within 60 seconds of server module removal to ensure proper chassis cooling. |
![]() | Caution - Hold the server module firmly with both hands so that you do not drop it. The server module can weigh as much as 20 pounds (9.0 kg). |
See Replace the Cover.
When the modular system is operating, you must fill every slot with a filler panel or a server module within 60 seconds.
Once installed, these server module activities take place:
Standby power is applied.
The front panel LEDs blink three times, then the green OK LED on the front panel blinks for a few minutes.
Oracle ILOM is initialized on the server module SP and is ready to use, but the server module host is not started.
See Powering On the Host.
