Install a Drive or Drive Filler
The physical address of a drive is based the
slot in which it is installed. See Drive Configuration.
Note - All drive bays must be populated with a drive or drive
filler.
- (If
needed) Remove a drive.
See Remove a Drive or Drive Filler.
- Identify the slot in which to
install the drive.
If you are replacing a drive, ensure
that you install the replacement drive in the same slot as the drive
you removed.
If you are adding an additional drive, install the
drive in the next available drive slot.
- (If needed) Remove the drive
filler from this slot.
- Slide the drive into the bay
until it is fully seated (panel 1).
- Close the latch to lock the drive
in place (panels 2 and 3).
- Consider your next step:
