See Remove the SP Card.
Ensure that the tab is aligned with the key.
When the SP card is in place, the lever will close.
See Log Into Oracle ILOM (Service).
This message might be displayed:
Unrecognized Chassis: This module is installed in an unknown or unsupported chassis. You must upgrade the firmware to a newer version that supports this chassis.
Refer to Servers Administration and to Oracle ILOM documentation for instructions.
Enter the datetime value in the form MMDDHHMMYYYY.
For example:
-> set /SP/clock datetime=091214052012
-> show /SP/clock
/SP/clock
Targets:
Properties:
datetime = Wed Sep 12 14:05:20 2012
timezone = PDT (PST8PDT)
uptime = 15 days, 02:36:54
usentpserver = disabled
If you are finished servicing components, see Returning the Server Module to Operation.
If you are servicing additional components, see Component Task Reference.
