When you replace an enclosure assembly, you must move a number of FRUs from the original server module to the same locations in the replacement assembly. See Component Locations.
When you transfer the SP and ID PROM from the old board to the new you preserve system-specific information that is stored on these modules.
When you replace the motherboard, the firmware on the new motherboard might be incompatible with the firmware on the SP. In this case, you must update the system firmware, which updates the SP and motherboard firmware to compatible versions.
Prepare to place all components on an antistatic mat unless you install each component immediately in the new enclosure assembly.
Follow the precautions explained in Preparing for Service.
See Remove the Cover.
See Servicing Drives.
Install the FEM in the same connectors in the enclosure assembly. See Servicing the FEM.
Ensure that you install a USB drive only in the top slot of the connector. See Servicing the USB Drive.
If a battery is present in the new enclosure assembly, do not transfer the original battery.
Move each DIMM to the same slot in the enclosure assembly. See Servicing DIMMs.
See Powering On the Host.
See Log Into Oracle ILOM (Service).
If the replacement SP detects that the SP firmware is not compatible with the existing host firmware, further action is suspended and this message is displayed:
Unrecognized Chassis: This module is installed in an unknown or unsupported chassis. You must upgrade the firmware to a newer version that supports this chassis.
If you see this message, go to Step 14. Otherwise, go to Step 15.
Refer to Servers Administration, Updating Firmware and to Oracle ILOM documentation for instructions.
This must be done in a special service mode by trained service personnel.
Use the values from the RFID on the new enclosure assembly.
The RFID on the original server module contains different values.
Power on the host – See Powering On the Host.
Run POST or Oracle VTS to verify the server module --- See Understanding Diagnostics and Tools.
