Go to main content
oracle home
SPARC T5-1B Server Module Service Manual
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
SPARC T5-1B Server Module Documentation Library
Identifying Components
Front and Rear Panel (Service)
Updated: February 2019
Document Information
Using This Documentation
Product Documentation Library
Feedback
Component Locations
Component Task Reference
Detecting and Managing Faults
Understanding Diagnostics and Tools
Diagnostics Process
Tool Availability
Log Into Oracle ILOM (Service)
Oracle ILOM Service-Related Commands
Interpreting LEDs
Front Panel Controls and LEDs
Configuring POST
POST Overview
Oracle ILOM Properties That Affect POST Behavior
Configure POST
Run POST With Maximum Testing
Managing Faults
PSH Overview
Check for Faults
Clear a Fault
Viewing Log Files and System Messages
Check the Message Buffer
View Log Files (Oracle Solaris)
View Log Files (Oracle ILOM)
Preparing for Service
Safety Information
Safety Symbols
ESD Measures
Antistatic Wrist Strap Use
Antistatic Mat
Tools Needed for Service
Find the Modular System Chassis Serial Number
Find the Server Module Serial Number
Locate the Server Module
Preparing the Server Module for Removal
Shut Down the OS and Host (Commands)
Shut Down the OS and Host (Power Button – Graceful)
Shut Down the OS and Host (Emergency Shutdown)
Set the Server Module to a Ready-to-Remove State
Remove the Server Module From the Modular System
Accessing Internal Components
Prevent ESD Damage
Remove the Cover
Servicing Drives
Drive Configuration
Drive LEDs
Drive Hot-Plugging Guidelines
Determine Which Drive Is Faulty
Remove a Drive or Drive Filler
Install a Drive or Drive Filler
Verify a Drive
Servicing DIMMs
DIMM Configuration
DIMM FRU Names
DIMM LEDs
Determine Which DIMM Is Faulty
Remove a DIMM
Install a DIMM
Verify a DIMM
Servicing the FEM
FEM Configuration
Remove a FEM
Install a FEM
Servicing the SP Card
Remove the SP Card
Install the SP Card
Servicing the ID PROM
Remove the ID PROM
Install the ID PROM
Verify the ID PROM
Servicing the USB Drive
Remove the USB Drive
Install a USB Drive
Servicing the Battery
Remove the Battery
Install the Battery
Servicing the Enclosure Assembly (Motherboard)
Transfer Components to the New Enclosure Assembly
Returning the Server Module to Operation
Replace the Cover
Install the Server Module Into the Modular System
Powering On the Host
Power On the Host (Oracle ILOM)
Power On the Host (Power Button)
Glossary
Index
Index A
Index B
Index C
Index D
Index E
Index F
Index H
Index I
Index L
Index M
Index O
Index P
Index R
Index S
Index T
Index U
Index V
Language:
English
No.
Description
Links
1
System LEDs
Interpreting LEDs
2
Power button
3
Reset button: NMI (for service use only)
4
Drive LEDs
Servicing Drives
5
Ejector arm latch
6
RFID tag (provides the serial number of the server module)
7
Top cover release button
Remove the Cover
8
UCP connector
Server Module Installation
, USB ports
9
Drive slots
Servicing Drives
10
Rear chassis power connector
11
Rear chassis data connection
Related Information
Interpreting LEDs
Component Locations
Previous
Next
