Use the following worksheets to record the existing configuration that you have for your Oracle SuperCluster T5-8, which affects the number and size of the zones that you can create. Also use the following worksheets to record the decisions about the number of zones and clusters that you are deploying, and the layout that you are using for the Exadata Storage Servers.
