Use this table to record the following information for each cluster that you are configuring:
Name of cluster (for example, osc01r1 or osc01r2)
Zones that are members of this cluster, and the Database Domains where they reside
Host name and IP addresses to be used for SCAN for each cluster
Clusters should span across multiple SPARC T5-8 servers for high availability. If you are creating a cluster, and a zone in a Database Domain is a member of that cluster on one SPARC T5-8 server, then other zones that are members of that cluster should be in a similar Database Domain on the second SPARC T5-8 server.
For example, assume you are creating a two-node cluster, where zone 1 in each Database Domain is a member of that cluster. To ensure high availability, this cluster should be created with the following zones as members of that cluster:
Zone 1 in Database Domain 1 in SPARC T5-8 server 1
Zone 1 in Database Domain 1 in SPARC T5-8 server 2
The worksheet has entries for ten clusters. But you can have more than ten clusters in your Oracle SuperCluster T5-8, depending on the number of Database Domains that have zones that are members of each cluster, the size of the zones in each cluster, and so on. Copy the worksheet if you have more than ten clusters in your system.
