Go to main content
Oracle® SuperCluster T5-8 Zones With Oracle Database on Database Domains Configuration Guide
Exit Print View
Updated: April 2020
Understanding an Example Scenario
The best way to illustrate how to decide how to lay out the Exadata Storage Servers is to provide an example scenario, which illustrates the process partly based on the amount of existing storage capacity that is available to you and how you want to carve that existing storage capacity up between the clusters. The following topics provide information on this example scenario:
