Use the following table to record your Exadata Storage Server disk group layout for each cluster. Note that the worksheet has entries for ten clusters, but you could have more than ten clusters in your Oracle SuperCluster T5-8, depending on the number of Database Domains that have zones that are members of each cluster, the size of the zones in each cluster, and so on. Copy the worksheet if you have more than ten clusters in your system.
Assign a name to each disk group that designates it as a specific type of disk group for a specific cluster, as described in Planning the Exadata Storage Server Disk Group Layout. For example, if the name of a particular cluster is osc01r1, then the names of the disk groups for that cluster should be something similar to the following:
DATA_osc01r1
RECO_osc01r1
DBFS_osc01r1
