You can configure the LSA retransmission interval to specify the amount of time between successive LSA retransmissions. You can also use the retransmission interval value to retransmit database description and link-state request packets.
This example configures VLAN 10 with a retransmission interval of 10 seconds.
SEFOS(config)# interface vlan 10 SEFOS(config-if)# ipv6 ospf retransmit-interval 10 SEFOS(config-if)# end
SEFOS# show ipv6 ospf interface vlan 10
Ospfv3 Interface Information
Interface Name: vlan10 Interface Id: 41 Area Id: 0.0.0.6
Local Address: fe80::214:4fff:fe6c:628f Router Id: 10.0.0.1
Network Type: BROADCAST Cost: 1 State: BACKUP
Designated Router Id: 10.0.0.8 local address: fe80::214:4fff:fe6c:d04d
Backup Designated Router Id: 10.0.0.1 local address: fe80::214:4fff:fe6c:628f
Transmit Delay: 1 sec Priority: 1 IfOptions: 0x0
Timer intervals configured:
Hello: 10, Dead: 40, Retransmit: 10, Poll: 120
Demand Circuit: Disable Neighbor Probing: Disable
Nbr Probe Retrans Limit: 10 Nbr Probe Interval: 120
Hello due in 7 sec
Neighbor Count is: 1
Adjacent with neighbor 10.0.0.8
