You can set the estimated time required to transmit a link-state update packet on the interface using the configuration in this section. Values are 1-1800 seconds.
This example configures VLAN 10 with a transmission delay of 5 seconds.
SEFOS(config)# interface vlan 10 SEFOS(config-if)# ipv6 ospf transmit-delay 5 SEFOS(config-if)# end
SEFOS# show ipv6 ospf interface vlan 10
Ospfv3 Interface Information
Interface Name: vlan10 Interface Id: 41 Area Id: 0.0.0.6
Local Address: fe80::214:4fff:fe6c:628f Router Id: 10.0.0.1
Network Type: BROADCAST Cost: 1 State: DR
Designated Router Id: 10.0.0.1 local address: fe80::214:4fff:fe6c:628f
Backup Designated Router Id: 10.0.0.8 local address: fe80::214:4fff:fe6c:d04d
Transmit Delay: 5 sec Priority: 1 IfOptions: 0x0
Timer intervals configured:
Hello: 10, Dead: 40, Retransmit: 5, Poll: 120
Demand Circuit: Disable Neighbor Probing: Disable
Nbr Probe Retrans Limit: 10 Nbr Probe Interval: 120
Hello due in 3 sec
Neighbor Count is: 1
Adjacent with neighbor 10.0.0.8
