You can configure the OSPFv3 hello interval to specify the interval between the hello packets sent on the interface. The hello interval value must be the same for all routers attached to a common link. Values are 1-65535 seconds.
This example configures VLAN 10 with a hello interval of 40 seconds.
SEFOS(config)# interface vlan 10 SEFOS(config-if)# ipv6 ospf hello-interval 40 SEFOS(config-if)# end
SEFOS# show ipv6 ospf interface vlan 10
Ospfv3 Interface Information
Interface Name: vlan10 Interface Id: 41 Area Id: 0.0.0.6
Local Address: fe80::214:4fff:fe6c:628f Router Id: 10.0.0.1
Network Type: BROADCAST Cost: 1 State: DR
Designated Router Id: 10.0.0.1 local address: fe80::214:4fff:fe6c:628f
Backup Designated Router Id: 10.0.0.8 local address: fe80::214:4fff:fe6c:d04d
Transmit Delay: 1 sec Priority: 1 IfOptions: 0x0
Timer intervals configured:
Hello: 40, Dead: 40, Retransmit: 5, Poll: 120
Demand Circuit: Disable Neighbor Probing: Disable
Nbr Probe Retrans Limit: 10 Nbr Probe Interval: 120
Hello due in 33 sec
Neighbor Count is: 1
Adjacent with neighbor 10.0.0.8
