This example configures an SPF delay time of 10 seconds and a SPF hold time of 20 seconds for SEFOS1 (router 10.0.0.1).
SEFOS# configure terminal
SEFOS(config)# ipv6 router ospf
SEFOS(config-router)# router-id 11.0.0.1
SEFOS(config-router)# timers spf 10 20 SEFOS(config-router)# end
SEFOS# show ipv6 ospf
Router Id: 10.0.0.1 ABR Type: Standard ABR
SPF schedule delay: 10 secs Hold time between two SPFs: 20 secs
Exit Overflow Interval: 0 Ref BW: 100000 Ext Lsdb Limit: -1
Trace Value: 0x00000800 As Scope Lsa: 1 Checksum Sum: 0xf0c7
Demand Circuit: Enable Passive Interface: Disable
Nssa Asbr Default Route Translation: Disable
It is an Area Border Router
Number of Areas in this router 2
Area 0.0.0.0
Number of interfaces in this area is 1
Number of Area Scope Lsa: 7 Checksum Sum: 0x2f2dc
Number of Indication Lsa: 1 SPF algorithm executed: 24 times
Area 0.0.0.6
Number of Area Scope Lsa: 7 Checksum Sum: 0x4c3fd
Number of Indication Lsa: 0 SPF algorithm executed: 25 times
