All OSPFv3 routes are maintained in RTM6. The RTM redistributes the best route. The RTM6 allows different routing protocols to exchange IPv6 routing information. This section describes the CLI and SNMP modes of configuration for route redistribution (static or dynamic) to routing protocols registered with RTM6.
While configuring redistribution, the protocol with routes to be redistributed into OSPFv3 is also configured.
This example enables route redistribution on SEFOS4 and specifies that static routes are redistributed.
SEFOS# configure terminal
SEFOS(config)# ipv6 router ospf
SEFOS(config-router)# router-id 10.0.0.4
SEFOS(config-router)# asbr router
SEFOS(config-router)# redistribute static
SEFOS# show running-config ospf3 Building configuration... ipv6 router ospf router-id 10.0.0.4 ASBR Router redistribute static ! interface vlan 4 ipv6 ospf area 0.0.0.3 ! interface vlan 11 ipv6 ospf area 0.0.0.0 ! end
