This example configures the external database limit in SEFOS1 (router 10.0.0.1) to 20 and the overflow exit interval in SEFOS1 to 10 seconds.
SEFOS# configure terminal
SEFOS(config)# ipv6 router ospf
SEFOS(config-router)# router-id 10.0.0.1
SEFOS(config-router)# as-external lsdb-limit 20 SEFOS(config-router)# exit-overflow-interval 10
SEFOS(config-router)# end
SEFOS# show ipv6 ospf
Router Id: 10.0.0.1 ABR Type: Standard ABR
SPF schedule delay: 5 secs Hold time between two SPFs: 10 secs
Exit Overflow Interval: 10 Ref BW: 100000 Ext Lsdb Limit: 20
Trace Value: 0x00000800 As Scope Lsa: 1 Checksum Sum: 0xf4c5
Demand Circuit: Enable Passive Interface: Disable
Nssa Asbr Default Route Translation: Disable
It is an Area Border Router
Number of Areas in this router 2
Area 0.0.0.0
Number of interfaces in this area is 1
Number of Area Scope Lsa: 7 Checksum Sum: 0x30ece
Number of Indication Lsa: 1 SPF algorithm executed: 22 times
Area 0.0.0.6
Number of Area Scope Lsa: 7 Checksum Sum: 0x4d7f3
Number of Indication Lsa: 0 SPF algorithm executed: 23 times
