See Creating the Base Configuration for Example Topologies for prerequisite configurations for SEFOS4, SEFOS5, and SEFOS7. See IPv6 Example Topology Interface and Host Addresses for the sample configuration of the stub, ASBR, and route redistribution areas.
This example shows how to configure SEFOS4 as an ASBR router for redistributing the external routes into the OSPF domain. This example also shows how to configure area 0.0.0.4 of SEFOS5 as a stub area, and how to configure area 0.0.0.4 of SEFOS7 as a stub area with external routes that are not redistributed into the stub area.
SEFOS# configure terminal SEFOS(config)# ipv6 router ospf SEFOS(config-router)# router-id 10.0.0.4 SEFOS(config-router)# asbr router SEFOS(config-router)# redistribute static SEFOS(config-router)# exit SEFOS(config)# ipv6 route 3333:: 96 fec0::4444:0:2 SEFOS(config)# exit
SEFOS# configure terminal SEFOS(config)# ipv6 router ospf SEFOS(config-router)# router-id 10.0.0.5 SEFOS(config-router)# area 0.0.0.4 stub SEFOS(config-router)# exit
SEFOS# configure terminal SEFOS(config)# ipv6 router ospf SEFOS(config-router)# router-id 10.0.0.7 SEFOS(config-router)# area 0.0.0.4 stub SEFOS(config-router)# exit
SEFOS# show ipv6 ospf route **************************************************** Dest/Prefix-Length NextHop/IfIndex Cost Rt.Type Area fec0::3003:0:0/96 fe80::207:2ff:fe03:401/vlan4 2 interArea 0.0.0.0 fec0::4444:0:0/96 :: /vlan4 1 intraArea 0.0.0.0 SEFOS# show ipv6 ospf database as-external detail Age: 0 Seconds LS Type: External Lsa Link State Id: 0.0.0.2 Adv Rtr Id: 10.0.0.4 Sequence: 0x80000001 Checksum: 0x0bc4 Length: 56 Metric Type: Ext Type2 Metric: 0xa Prefix Length: 96 Prefix Options: 0x00 Referenced LS Type: 0 Address Prefix: 3333:: Fw Address Prefix: 3333::fec0:0 External Route Tag: 0
SEFOS# show ipv6 ospf route OSPFV3 Process Routing Table Dest/Prefix-Length NextHop/IfIndex Cost Rt.Type Area 3333::/96 fec0::4444:0:2/vlan4 10 type2Ext 0.0.0.0SEFOS# show ipv6 ospf database as-external detail fec0::3003:0:0/96 ::/vlan5 1 intraArea 0.0.0.4 fec0::4444:0:0/96 ::/vlan4 1 intraArea 0.0.0.3Age: 63 Seconds LS Type: External LsaLink State Id: 0.0.0.2 Adv Rtr Id: 10.0.0.4Sequence: 0x80000001 Checksum: 0x0bc4 Length: 56Metric Type: Ext Type2 Metric: 0xaPrefix Length: 96 Prefix Options: 0x00Referenced LS Type: 0Addres Prefix: 3333::Fw Addres Prefix: 3333::fec0:0External Route Tag: 0
